Scheduled recording
kentek
Sadly, as far as I am aware there is no way of scheduling a recording with the RH1. If you put the RH1 into Record/Pause it will turn itself off after 5 minutes if it does not detect any sound. Only a deck has the ability to record in this way and of course there are no Hi MD decks. If you do have a deck then you can record and upload to the computer from the RH1...
