heathenmagic Posted November 17, 2006 Report Share Posted November 17, 2006 Hello there,Just Acquired a MZ-DH10P. I know how to take a pic of cover art, but the manual mentions Aut Import of Cover Art, and also the right Click on Hi-MD contents yields a ghosted Import Art. Wonder if this ability no longer exists, or I am missing something. Auto Import is at the bottom right of SonicStage in the manual, but can't see it for the trees!! Be grateful for any help.Thanks Quote Link to comment Share on other sites More sharing options...
Richard Posted November 18, 2006 Report Share Posted November 18, 2006 If an album already has cover art assigned to it in the SS library, when you transfer the album the art should come across automatically.You can either assign jpeg's manually in SS by attaching them in the properties screen of the album - or if CDDB finds the cover and it pops up in the bottom right of the screen, drag it into the little square on the playback section of the toolbar and it will be added as the cd is imported. You can also copy cover art between albums in the library using a similar drag n drop method.* Moved to Software Discussion Quote Link to comment Share on other sites More sharing options...
heathenmagic Posted November 19, 2006 Author Report Share Posted November 19, 2006 If an album already has cover art assigned to it in the SS library, when you transfer the album the art should come across automatically.You can either assign jpeg's manually in SS by attaching them in the properties screen of the album - or if CDDB finds the cover and it pops up in the bottom right of the screen, drag it into the little square on the playback section of the toolbar and it will be added as the cd is imported. You can also copy cover art between albums in the library using a similar drag n drop method.* Moved to Software DiscussionThanks Richyhu,Will try dragging it into the playback toolbar, many thanks for your help. Quote Link to comment Share on other sites More sharing options...
