prodigyresources Posted November 22, 2006 Report Share Posted November 22, 2006 What format is the best for playing audio books. I get them from everywhere(itunes, audible.com, etc) I don't understand why i can't load mp4 audio books from itunes onto my MD, but i'm retarded. I would like to add trackmarks so that i can mark stuff to go back and restudy. Quote Link to comment Share on other sites More sharing options...
raintheory Posted November 22, 2006 Report Share Posted November 22, 2006 (edited) Unfortunately I believe the only way to be able to add track marks would be if you record in realtime via line/optical input... Frustrating, but material downloaded to (Hi)MD from PC cannot be edited/trackmarked.Silly really, and if Sony wants to focus more on the recording aspect of MD this will need to definitely be fixed. Edited November 22, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
curls Posted November 22, 2006 Report Share Posted November 22, 2006 Easiest way is probably to split the file into a number of smaller files, say 5 minutes long, before downloading to MD. There are programs that can do this automatically. Quote Link to comment Share on other sites More sharing options...
ATELETRONICS Posted November 22, 2006 Report Share Posted November 22, 2006 if you had a net md and use simple burner you can manually add track marks as you listen the files are not write protected. does this work this way with hi-md simple burner if so he could just convert them to virtual audio cd's then use simple burner then add track mark while he listens? Quote Link to comment Share on other sites More sharing options...
Richard Posted November 22, 2006 Report Share Posted November 22, 2006 * Moved to Software Discussion Quote Link to comment Share on other sites More sharing options...
raintheory Posted November 22, 2006 Report Share Posted November 22, 2006 if you had a net md and use simple burner you can manually add track marks as you listen the files are not write protected. does this work this way with hi-md simple burner if so he could just convert them to virtual audio cd's then use simple burner then add track mark while he listens?Interesting, I'll experiment with this and let you guys know. Would be great if this works! Quote Link to comment Share on other sites More sharing options...
raintheory Posted November 22, 2006 Report Share Posted November 22, 2006 if you had a net md and use simple burner you can manually add track marks as you listen the files are not write protected. does this work this way with hi-md simple burner if so he could just convert them to virtual audio cd's then use simple burner then add track mark while he listens?Well, I did a bit of testing and this method in fact only works with NetMD. I tried Hi-MD formats and simply got the "Track From PC No Edit" message. Good to know that there is still some usefulness to the old Nero ImageDrive/SimpleBurner method. Only downside is that you have to transcode to LP2/LP4. Quote Link to comment Share on other sites More sharing options...
prodigyresources Posted November 25, 2006 Author Report Share Posted November 25, 2006 Okay, thanks guys. We'll i'm obviously new to this. I broke out the old netmd cuz keeping up with technology is no fun for me anymore. I tried an ipod and itunes, etc and all the complication, for profits sake annoyed me. Can you break it down for me. So your saying I can't use the sonic stage that i just downloaded, i need to do a search for Nero or simple burner(don't have original software). And convert the mp3/aac/pos(kinda file that i get from the audiobook site) to a cd format(wav?) and then convert it to LP4. I think i must have missed something. Thanks Quote Link to comment Share on other sites More sharing options...
