boojum Posted March 2, 2007 Report Share Posted March 2, 2007 Hi - I am recording two bands now. One I just record it, ad some ReplayGain and post it to etree. The other, a local bluegrass group, would like to see some bass boost (my mic drops off bel;ow 70Hz) and so on. Cool Edit does not seem to do bass boost but Audicity does. But it also requires a separate pass for each boost, as in 100Hz, 200 Hz, etc., and then a separate pass to raise the volume. Is there a post processing piece if free software which wil do this in all one pass??? I can work with Audacity, but would like to do it all at once after I know the settings for each venue.Thanks. Quote Link to comment Share on other sites More sharing options...
Richard Posted March 2, 2007 Report Share Posted March 2, 2007 * Moved to Software Discussion Quote Link to comment Share on other sites More sharing options...
A440 Posted March 2, 2007 Report Share Posted March 2, 2007 In Audacity under Effect, Equalization allows you to set your own curve. Push around the blue line with your cursor. Cool Edit must also have EQ--I don't have it loaded in this computer, but it's probably more fine-tuned. Quote Link to comment Share on other sites More sharing options...
boojum Posted March 2, 2007 Author Report Share Posted March 2, 2007 PA - Thanks for the help. I poked around under "mixer" rather than function: "equalizer." I will try Cool Edit first.The low frequencies are there from the MS957. They are just shy and need some coaxing.Cheers. Quote Link to comment Share on other sites More sharing options...
ozpeter Posted March 3, 2007 Report Share Posted March 3, 2007 If still looking, try Reaper - it's built in ReaEQ in the latest version is rather nice - easy to use. 2Mb download and unlimited uncrippled trial. Quote Link to comment Share on other sites More sharing options...
boojum Posted March 3, 2007 Author Report Share Posted March 3, 2007 ozpeter said: If still looking, try Reaper - it's built in ReaEQ in the latest version is rather nice - easy to use. 2Mb download and unlimited uncrippled trial.I have downloaded Reaper. It looks like it can do more than I need. I will play with it, try to learn it, and see what happens. Thanks! Quote Link to comment Share on other sites More sharing options...
