Sharp MDMT-15 Mic Input
monradon
Is the mic input on my Sharp MDMT-15 Stereo ???? If it is not stereo do stereo mics work with this unit ???? Need a new mic and not sure which one to get , I know this is older but it still does a great recording. Bunch of music festivals coming up need a mic quick. email is monradon@msn.com
It should be stereo, with a plug exactly the same as the one on your stereo headphones: two circular bands around the plug.
In fact, you can test its stereo-ness by plugging your headphones into the mic jack, starting Record, and then tapping on each earpiece, left and right. The headphone will act like a weak mic and you should be able to hear each channel separately on the playback.
Yes, it is definitely stereo.
