803cd Posted October 20, 2007 Report Share Posted October 20, 2007 I'm currently using SS4.2 and simple burner. To resolve a non SS related problem I need to format my hard drive and re-install XP. If I install SS 4.3 is it possible to also use simple burner - I remember reading that simple burner is now discontinued. Quote Link to comment Share on other sites More sharing options...
Richard Posted October 20, 2007 Report Share Posted October 20, 2007 Simple Burner 2.x is still supported and runs fine on XP It's just on Vista that it isn't supported. Quote Link to comment Share on other sites More sharing options...
Avrin Posted October 20, 2007 Report Share Posted October 20, 2007 (edited) Why would you want to install SS43? It is only designed to make things funnier under Vista. Edited October 20, 2007 by Avrin Quote Link to comment Share on other sites More sharing options...
raintheory Posted October 20, 2007 Report Share Posted October 20, 2007 I would recommend sticking with SonicStage 4.2... 4.3 only offers Vista compatibility over 4.2, otherwise it is identical. However, when I installed 4.3 on XP (on 2 different computers) I experienced a number of problems including being unable to upload.SimpleBurner is available in the downloads section of the forums: http://forums.minidisc.org/downloads/details.php?file=93 (use your forum login) Quote Link to comment Share on other sites More sharing options...
