jernikfra Posted October 30, 2007 Report Share Posted October 30, 2007 I just got my RM-MC40ELK remote and used it today for the first time with my MZ-EH70.It is a big inprovement over the RM-MC38ELK.The only bummer is the menu options are all in Japanese.If anyone knows how to change them , please let me know, since they are all in English when i plug in the RM-MC38ELK.Weird, you would think the player generates the characters, as oppose to the remote.I will post a pictorial soon for members to enjoy! Quote Link to comment Share on other sites More sharing options...
bland10000 Posted October 30, 2007 Report Share Posted October 30, 2007 (edited) You must have a smudge on that 38el and are assuming it is a "k". To turn off kanji on the 40elk... 1) Select: 各種設定 / Option2) Select: 表示言語 / Language3) Select: 日本語 or English Edited October 30, 2007 by bland10000 Quote Link to comment Share on other sites More sharing options...
jernikfra Posted October 30, 2007 Author Report Share Posted October 30, 2007 bland10000 said: You must have a smudge on that 38el and are assuming it is a "k". To turn off kanji on the 40elk... 1) Select: 各種設定 / Option2) Select: 表示言語 / Language3) Select: 日本語 or EnglishMission accomplished! thanks so much SHARP AUVI DRESSED MAN! Pictures to follow! Quote Link to comment Share on other sites More sharing options...
bland10000 Posted October 30, 2007 Report Share Posted October 30, 2007 (edited) Since the 35 is an "ELK" and the 40 is also, I think alot of us expected the 38 to be kanji "K" capable, too.... Edited October 30, 2007 by bland10000 Quote Link to comment Share on other sites More sharing options...
Avrin Posted October 30, 2007 Report Share Posted October 30, 2007 The player does not generate any characters on the remote outputs. It simply sends character codes, and then the remote uses these codes to pick up actual characters from its internal memory chip. Only the "K" remotes have kanji and some other languages, such as Greek and Russian, in their memory. Non-"K" remotes have a smaller and cheaper memory, which does not contain kanji, Russian or Greek. Quote Link to comment Share on other sites More sharing options...
