jjstokes Posted February 10, 2008 Report Share Posted February 10, 2008 I have a MZ-n707 player, is it compatible with a 1GB Hi-MD disc?If not, whats the longest player time that is availabe for the player that i have right now? Quote Link to comment Share on other sites More sharing options...
Strungup Posted February 10, 2008 Report Share Posted February 10, 2008 jjstokes said: I have a MZ-n707 player, is it compatible with a 1GB Hi-MD disc?If not, whats the longest player time that is availabe for the player that i have right now?No it isnt a HiMD , and LP 4 mode will be 4 times the disc you put in , (ie.80 minute disc x4 , 74x4 , etc) Quote Link to comment Share on other sites More sharing options...
jjstokes Posted February 10, 2008 Author Report Share Posted February 10, 2008 (edited) thanks Edited February 10, 2008 by jjstokes Quote Link to comment Share on other sites More sharing options...
jjstokes Posted February 10, 2008 Author Report Share Posted February 10, 2008 Guitarfxr said: No it isnt a HiMD , and LP 4 mode will be 4 times the disc you put in , (ie.80 minute disc x4 , 74x4 , etc)do i have to get a mini disc that allows me to play LP4 mode. I found the LP4 mode on sonic stage, but it wont let me tranfer the track.... Its a voice recording. Quote Link to comment Share on other sites More sharing options...
Strungup Posted February 10, 2008 Report Share Posted February 10, 2008 jjstokes said: do i have to get a mini disc that allows me to play LP4 mode. I found the LP4 mode on sonic stage, but it wont let me tranfer the track.... Its a voice recording.Voice ? what format ? mp3 , or wma , or ...... MD only play ATRAC , so you would have to convert the file in Sonic Stage first , I am on Mac so a windows guy will have to answer that one . Quote Link to comment Share on other sites More sharing options...
jjstokes Posted February 10, 2008 Author Report Share Posted February 10, 2008 Guitarfxr said: Voice ? what format ? mp3 , or wma , or ...... MD only play ATRAC , so you would have to convert the file in Sonic Stage first , I am on Mac so a windows guy will have to answer that one .The voice recording that i have is about 100 minutes. I can transfer a 3 min. song to the MD player but not the 100 min voice recording. On sonic stage i selected LP4 mode but it doesnt go thru. Also, sonic stage is saying that my device/media/minidisc has 80 mins of free space on it (based on SP mode)?Do i need to get a new disc?thanks Quote Link to comment Share on other sites More sharing options...
Strungup Posted February 10, 2008 Report Share Posted February 10, 2008 jjstokes said: The voice recording that i have is about 100 minutes. I can transfer a 3 min. song to the MD player but not the 100 min voice recording. On sonic stage i selected LP4 mode but it doesnt go thru. Also, sonic stage is saying that my device/media/minidisc has 80 mins of free space on it (based on SP mode)?Do i need to get a new disc?thanksyou didnt answer my question ,..........what FORMAT is the voice recording , ... What type of File is it , is it an MP3 , is it WMA , is it OGG , what FORMAt is it , SS can only convert certain types of files to ATRAC format . Quote Link to comment Share on other sites More sharing options...
jjstokes Posted February 10, 2008 Author Report Share Posted February 10, 2008 (edited) Guitarfxr said: you didnt answer my question ,..........what FORMAT is the voice recording , ... What type of File is it , is it an MP3 , is it WMA , is it OGG , what FORMAt is it , SS can only convert certain types of files to ATRAC format .both MP3 and wma. now its oma Edited February 10, 2008 by jjstokes Quote Link to comment Share on other sites More sharing options...
Strungup Posted February 10, 2008 Report Share Posted February 10, 2008 jjstokes said: both MP3 and wma. now its omawill it play in SS?if it wont download to the player , then record it directly from the line out of you computer, to the MD Quote Link to comment Share on other sites More sharing options...
bobt Posted February 10, 2008 Report Share Posted February 10, 2008 What version os SS are you using? It should be at minimum 3.4, if not 4.2 or 4.3 if you are on Vista. When you get to transfer there is a small square that gives you tranfer settings, if not go to properties, and set from there.BobAlso realize that with the 707 it is a one way street, you will not be able to go back to the puter with your file, you can check it back in, but it won't upload Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted February 10, 2008 Report Share Posted February 10, 2008 Or perhaps 100 min is too long to transfer as one file, though in theory you have enough space - 80 mins SP means 320 mins LP4. You should be able to chop up the .oma file a bit using the Edit > Divide function in Sonictstage. Also what error message do you get when trying to transfer the whole file? Maybe there's snme copy protection in force or something like that? Quote Link to comment Share on other sites More sharing options...
jjstokes Posted February 11, 2008 Author Report Share Posted February 11, 2008 holycrap i just figured it. call me stupid. The batteries were low on the MD playerthanks everyone Quote Link to comment Share on other sites More sharing options...
Strungup Posted February 11, 2008 Report Share Posted February 11, 2008 jjstokes said: holycrap i just figured it. call me stupid. The batteries were low on the MD playerthanks everyoneummmm your supposed to have it plugged in when doing transfer I believe???????????? Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted February 11, 2008 Report Share Posted February 11, 2008 i always do my transfers with battery power. it always works fine. Quote Link to comment Share on other sites More sharing options...
BobS Posted February 11, 2008 Report Share Posted February 11, 2008 Glad you found it. Just a comment on another post, there is no 100 min limit. I have regularly transferred files over 120 min with no problem. I expect you could fill an entire disk with one file with no problem Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted February 12, 2008 Report Share Posted February 12, 2008 lp4 is really bad you should not use it unless it is for pure speech only! Quote Link to comment Share on other sites More sharing options...
