madleet3 Posted March 17, 2006 Report Share Posted March 17, 2006 iread the manual but dont gimme any info on playlist but on SS its got a functions called playlistanyway to have a playlist? Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted March 18, 2006 Report Share Posted March 18, 2006 Go to my Library =>Click on create /edit playlist (See on the top /SSver3.4)..Then in the bottom click on Create a new playlist .After naming it click on the playlist folder=>Then transfer the songs you want from the left side .. Quote Link to comment Share on other sites More sharing options...
0 madleet3 Posted March 18, 2006 Author Report Share Posted March 18, 2006 but we cant edit playlist on the fly on our E507 right?can only edit on the pc and transfer over? Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted March 18, 2006 Report Share Posted March 18, 2006 but we cant edit playlist on the fly on our E507 right?can only edit on the pc and transfer over?Yes ,You are right . Quote Link to comment Share on other sites More sharing options...
0 Hurryken Posted March 19, 2006 Report Share Posted March 19, 2006 (edited) But these playlists, ain't they just a new folder for the songs in the library?For me, real playlists are bookmarks for the songs (like the ones you create in winamp ...). They don't take any space on the device.... Is it possible to create something like that in Sonic Stage?*and sorry for my bad english ;-)* Edited March 19, 2006 by Hurryken Quote Link to comment Share on other sites More sharing options...
0 madleet3 Posted March 20, 2006 Author Report Share Posted March 20, 2006 yea after i tested on Playlist on mye507 and transfterits seem to be folders not real playlist so i just make do and orgaanize on folder just for my songs i consider playlistseems sony playlist works difffrom others DAP Quote Link to comment Share on other sites More sharing options...
0 RedemptioN419 Posted March 21, 2006 Report Share Posted March 21, 2006 I think the Sony Folders are a lot better because you can switch folders, or playlists by extending the shuttle and search for the folder. In other DAP's, you would have to go to 'music', 'playist' and choose which one. In the Sony DAP's, you can do it without looking. Quote Link to comment Share on other sites More sharing options...
0 dtrain Posted May 2, 2006 Report Share Posted May 2, 2006 Hello,I have a related question. Is it possible to pull a playlist together from songs already on the device? I like to have the individual songs kept together within their album structures on the device but I'd also like to have a mix of certain songs pulled together as their own album without having the songs on there twice. I have an NWE507 and SS3.4.Thanks!!!Dtrain Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted May 3, 2006 Report Share Posted May 3, 2006 Hello,I have a related question. Is it possible to pull a playlist together from songs already on the device? I like to have the individual songs kept together within their album structures on the device but I'd also like to have a mix of certain songs pulled together as their own album without having the songs on there twice. I have an NWE507 and SS3.4.Thanks!!!DtrainIt`s not possible with E500/E400 series ..but with A600(series) Quote Link to comment Share on other sites More sharing options...
madleet3
8 answers to this question
