USB cable for an MZ-NH700
sashcat
Hi :)
I've just bought an MZ-NH700 from ebay, it did not come with a USB cable or a rechargeable battery.
I've looked through the forums here and it seems that I need a USB Type A Connector to a standard USB Mini B Connector.
However looking on ebay there are 2 types of USB Mini B, a 4 pin type and a 5 pin type.
Which one should I buy?
Also I'd like to buy a rechargeable battery for my MZ-NH700.
In the minidisc.org browser it says "Rechargeable NiMH AA formfactor battery (NH-7WMAA)"
I can't find any NH-7WMAA, so I was wondering which rechargable battery to buy?
I look forwards to your help, and using my MZ-NH700 :)
Edited by sashcat
There are better AA rechargeables that those issued with the player, and you can pick these up almost anywhere (try your local supermarket).
The USB cable is not that uncommon, with several devices using the same mini plug - I would try somewhere like PC World, Curry's or the like (if you live in the UK!).
So basically buy any AA rechargable battery in the shop?
On ebay there are 2 types of USB Mini B, a 4 pin type and a 5 pin type.
Please accept my apologies, I never read your post correctly...
These ones on ebay will do the job: -
http://cgi.ebay.co.uk/USB-2-0-Cable-For-So...id=p3286.c0.m14
and...
http://cgi.ebay.co.uk/USB-Cable-Lead-For-S...id=p3286.c0.m14
Any AA battery will do, but I actually use Sony branded, non-Walkman, rechargeable AA's which seem to offer better battery life. These same batteries also last longer than the supplied AA's in my Sony Cybershot digital camera.
