albero23 Posted April 11, 2006 Report Share Posted April 11, 2006 hi all,i'm new in this forum and i like it so much above all it's very usefuli would ask if there is any other software for rating songs with stars and add info to the song to abilitate the link keyanother question can GYM transfer songs from pc to the device?thanks for your help Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted April 11, 2006 Report Share Posted April 11, 2006 Welcome to the forums !SonicStage ver3.4 can also do that .You can`t use GYM to tranfer songs from PC to device . Quote Link to comment Share on other sites More sharing options...
0 albero23 Posted April 11, 2006 Author Report Share Posted April 11, 2006 really? i can't find any way on GYM to transer song from pc to the device i've the version 1.2 betacould you please make a screenshot?thank Quote Link to comment Share on other sites More sharing options...
0 MDX-400 Posted April 11, 2006 Report Share Posted April 11, 2006 LOL. He just said you can't use GYM to do that. It only allows you to play and pull tracks in the MP3 format which are on the device. Quote Link to comment Share on other sites More sharing options...
0 albero23 Posted April 11, 2006 Author Report Share Posted April 11, 2006 i'm sorry i red badanyway sonicstage dn't allow me to rate song and use the link key because when i try to see the rste or to us e the link key the device tell me to connect whit compliant software... Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted April 12, 2006 Report Share Posted April 12, 2006 i'm sorry i red badanyway sonicstage dn't allow me to rate song and use the link key because when i try to see the rste or to us e the link key the device tell me to connect whit compliant software...Sorry for creating some confusion..SonicStage is not full compatoble with A-series .If you use SoncStage then some features like Artist link ,Intelligent shuffle with be disabled Quote Link to comment Share on other sites More sharing options...
0 albero23 Posted April 12, 2006 Author Report Share Posted April 12, 2006 thank stuge for everythingbut sony shouuld work to make a working version of connect Quote Link to comment Share on other sites More sharing options...
albero23
6 answers to this question
