seem Posted June 24, 2009 Report Share Posted June 24, 2009 Hi guys,am new here, and with minidiscs and i need some help please,i bought a mz ne410 minidisc via ebay-used, and i have a problem:when i try to upload files using Sonic stage 4.3 or simple burner, it may upload only one track or not, then my system crashes (blue screen with errors and i need to to reboot) neither in windows vista or windows XP, i had tried with several discs, and several tracks, the usb cable is fine, usb ports too.. i downloaded new drivers, try two different versions of sonic stage, and the issue had not been solved..Help Please !before i ask for my money back.. Quote Link to comment Share on other sites More sharing options...
Strungup Posted June 24, 2009 Report Share Posted June 24, 2009 Ask for your money back , Save up for an RH1 Quote Link to comment Share on other sites More sharing options...
sfbp Posted June 24, 2009 Report Share Posted June 24, 2009 when i try to upload files using Sonic stage 4.3 or simple burner, it may upload only one track or not,Do you really mean "upload" (as commonly accepted here, upload is MD->PC)?If you mean download, my first thought would be: check the battery contacts for guck, and put a brand new non-rechargeable battery in there for testing. This unit CANNOT draw power from the USB. Quote Link to comment Share on other sites More sharing options...
seem Posted June 24, 2009 Author Report Share Posted June 24, 2009 Do you really mean "upload" (as commonly accepted here, upload is MD->PC)?If you mean download, my first thought would be: check the battery contacts for guck, and put a brand new non-rechargeable battery in there for testing. This unit CANNOT draw power from the USB.i mean that i want to put music into the minidisc PC-->MD, and the system crashes after one track and somtimes nothing, i can't put track after track also.. i use brand new, non-rechargable battery..the player plays the discs great, but i can't record into it.. could sony have a support or can help with this ? Quote Link to comment Share on other sites More sharing options...
sfbp Posted June 25, 2009 Report Share Posted June 25, 2009 i mean that i want to put music into the minidisc PC-->MD, and the system crashes after one track and somtimes nothing, i can't put track after track also.. i use brand new, non-rechargable battery..the player plays the discs great, but i can't record into it.. could sony have a support or can help with this ?Can you actually play back even ONE track that you just downloaded onto it? Quote Link to comment Share on other sites More sharing options...
seem Posted June 25, 2009 Author Report Share Posted June 25, 2009 Can you actually play back even ONE track that you just downloaded onto it?yes only one. but not all times. Quote Link to comment Share on other sites More sharing options...
sfbp Posted June 25, 2009 Report Share Posted June 25, 2009 something mechanical, or power, thenusually when the writing circuit dies it is not intermittent. if it suddenly gets worse then you have the answer.however I would clean the battery terminals with some contact cleaner and a qtip Quote Link to comment Share on other sites More sharing options...
