Denon DMD-1600 manual needed!
wadesun
Hello all, I bought a second-hand Denon Minidisc Deck, DMD-1600ALB, but am having trouble locating the manual online. I've tried contacting Denon USA support, but they cannot find the manual because this particular unit is a Japanese unit. I also went to Denon's Japanese website, but since I cannot read Japanese, I can't locate the manual. They do have the unit under their products, but I can't seem to find the manual (maybe because I can't read Japanese?). I also tried searching on this board, but can't find it. Does anyone have idea where I can find the manual? Thanks much!
Edited by wadesun
Welcome to the forums!
With whatever's left of my Japanese, I'm also unable to find the manual for the DMD-1600 at their website. The closest match is the Japanese manual for the DMD-1550 here: http://www.denon.co.jp/ownersmanual/pdf/dmd1550.pdf
But there is a scan of the English manual for DENON DMD-1000 here at the minidisc.org site: http://www.minidisc.org/manuals/denon_dmd1000_manual.pdf - it may be of some help.
You may be out of luck unless it is similar enough in operation to one of the other models with English manuals. As you probably discovered, the closest model they have with a manual is the 1550--but that manual is only in Japanese.
  • 4 weeks later...
