Loque Posted August 12, 2009 Report Share Posted August 12, 2009 I know the constant and entriely justified bleating about sonicstage that continually plagues MD, but I use OS X for most of my computing, either that or 64bit OS. The prospect of an MD working well on a Mac computer excites me, does anybody know how well the system that Sony have added for OS X (On the RH-1) works? Quote Link to comment Share on other sites More sharing options...
bobt Posted August 15, 2009 Report Share Posted August 15, 2009 I know the constant and entriely justified bleating about sonicstage that continually plagues MD, but I use OS X for most of my computing, either that or 64bit OS. The prospect of an MD working well on a Mac computer excites me, does anybody know how well the system that Sony have added for OS X (On the RH-1) works?PM guitarfixr, he has a macBob Quote Link to comment Share on other sites More sharing options...
kindacloudy Posted August 17, 2009 Report Share Posted August 17, 2009 My MZ-RH1 works pretty well within OSX as long as you are importing material recorded on Hi-MD media. If you have any old format disks you want to import you will need to do this via Windows. I use XP in VMWare and it works really well for getting this old stuff back.Bare in mind that the Hi-MD transfer software for Mac is an old PowerPC app and can run a little slowly on Intel macs. Other than that it's all good.Cheers Quote Link to comment Share on other sites More sharing options...
sallymae_hogsby Posted August 17, 2009 Report Share Posted August 17, 2009 I've used the Mac-MD software for awhile. I works okay for what it does. But I ended up just getting a PC netbook (with XP) and using a 2GB memory stick for copying files to my Mac. Less limitations and frustration. Quote Link to comment Share on other sites More sharing options...
Strungup Posted September 10, 2009 Report Share Posted September 10, 2009 <!--quoteo(post=145669:date=Aug 12 2009, 11:45 AM:name=Loque)--><div class='quotetop'>QUOTE (Loque @ Aug 12 2009, 11:45 AM) <a href="index.php?act=findpost&pid=145669"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->I know the constant and entriely justified bleating about sonicstage that continually plagues MD, but I use OS X for most of my computing, either that or 64bit OS. The prospect of an MD working well on a Mac computer excites me, does anybody know how well the system that Sony have added for OS X (On the RH-1) works?<!--QuoteEnd--></div><!--QuoteEEnd--> PM guitarfixr, he has a mac Bob Bob he will have to PM ( Me ) TC- , because my other account isnt accessible (Guitarfxr) I know the constant and entriely justified bleating about sonicstage that continually plagues MD, but I use OS X for most of my computing, either that or 64bit OS. The prospect of an MD working well on a Mac computer excites me, does anybody know how well the system that Sony have added for OS X (On the RH-1) works? Me Macbook Pro C2D , Sony RH1 , MD Transfer 2.0 . Your recordings that are done in HiMD mode will upload in WAV format to your desktop . Title all tracks before Uploading ( Using the same software ) Just select ,type and hit enter for each track as you edit, then Select all , Upload to your desktop , put them in a Folder for Burning , I Use" Burn " for Mac , because it is very clean , does it well and does it free , Data Discs , Audio , DVD , Divx , MP3 , etc Quote Link to comment Share on other sites More sharing options...
