MD simple burner
cm16600
I'm afraid that the downloads section here has gone AWOL, which is the only place I ever knew to get it. Perhaps some bright spark could upload a copy and point you there. I had a look and came to the conclusion the best place might be on the CD you received (if you got one).
Note that you will need SonicStage of some variety installed as well, unless you're willing to do some geek-type stuff with installer packages.
