my new JE980
bobt
Finally got my 980, and a power supply to give me 220, plug it in, disappointment, no action, nothing, took the top off, found the power supply broken into three pieces, box showed no outward signs of shock, deck only had the imperfection that was noted. Pictures show the deck in operation, so somewhere between, France, Iceland, and Cayman, the box was subjected to extreme deceleration and shock. Philippe, Piere, and I are trying for a solution, but I was wondering if anyone stateside, Canadaside, or anywhere else have access to a Sony repair facility on getting a new power supply. The only number on the power supply is JE780ES which tells me supplies are interchangeable, if I could find a 120 volt power supply it would be great, if not, I do have the adapter.
You can also e-mail me at bobt@candw.ky
Thanks
Bob
Bobt I think you receive the Sony JB980 serie QS, not JE980.
http://www.minidisc.org/part_Sony_MDS-JB980.html
I read on your picture a reference on power supply card : JE780, something is hidding other letters on the picture but for sure there is not a JE780ES in the ES serie.
http://www.minidisc.org/part_Sony_MDS-JE780.html
The number on the power supply is MDS JE780PT
  On 3/3/2010 at 12:25 PM, bobt said:
No one around that can check with Sony? weird!
Bob
Isn't one problem that no-one has ever actually set eyes on a service manual for the 980?
If you can find one on one of these sites that sell them, I would go halves with you on it.
Stephen
Stephen
The problem from my end is that Sony even in a so called international site does not want to sell out of it's jurisdiction, getting anything electronic out of the states is next to impossible unless someone brings it over, their draconian security issues, plenty of terror in a power supply. Japan has refused to answer my e-mails, tres frustrating!
Bob
