Stereo option
Geza
Simply trying to build up to 7.1 so at this stage I only have 2 speakers. What is the correct way to connect so as to be able to listen to TV and DVD and hear all audio. I have connected via HDMI as I want to utilise all 3 HDMI inputs and switch between them
3 answers to this question
Hmm guessing the one step you may have missed is to set ur receiver NOT to send sound to the TV.
Also for direct TV broadcasts (as opposed to via one of the other sources) its possible you need an optical (or coax) cable in the reverse direction.
