GYM Problem
sh33p
I'm using GYM 1.2b on my NWA3000 and it loads up fine, I can browse and save tracks, but if I select a track and try to play it the program just freezes, any suggestions?
Common problem for all of us at one point or another.
Search the forum and read up on it.
Uninstall and reinstall, perhaps you'll get lucky
I'm using the winamp plugin now with winamp installed on the nwa3000.
the gym problem is unusual because it works perfectly on all computers except my own, which is why i don't really think it's a gym problem at all... dunno what it is though. i'm using .NET 1.1 not 2.0...
Guest Stuge
Some program on your computer maybe interfering with GYM .
I could be wrong, but was there not a warning about using the winamp plug-in and then being able to use GYM/SS again?
I believe there was. You should check in on that and ask in the ml_sony thread.
  • 3 weeks later...
Doesn't matter 'cos GYM didn't work even before ML_SONY and after ML_SONY GYM is the same, i.e. Doesn't play on my pc but works fine elsewhere.
As I said before, uninstall and re-install.
Several of us have had this problem. It took my 3/4 times and I ran through all the trouble shooters.....checking WMP, SS, Netframework blah blah blah. Then magically it worked.
