An Invalid Argument Was Encountered
Walkieman
3 answers to this question
If you didn't decrypt the tracks (File Conversion Tool) then you will need to reauthenticate the db. This requires access to the internet, as a minimum. If you haven't messed up too much on the Windows partition you may be ok. If you formatted it fresh, you are out of luck. However there is now, or soon, a version of ffmpeg that can convert all your tracks. But it will take you a long time if there are lots of them. In the old days you would have lost the lot.
