Juan22 Posted December 13, 2011 Report Share Posted December 13, 2011 Hello everyone, I've been having some problems making copies of some recordings and im trying to switch from 'headphones' to 'line-out' but I don't see any line-out options in the user manual of the recorder, however it says in the minidisc.org description of the MZ-R70 that it can switch between the two... Has anyone been able tu use this function on this unit? thanks in advance -Juan Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 13, 2011 Report Share Posted December 13, 2011 The only "two" I see in the manual is the double headphone sockets. See page 37 of the manual. They tell you to set output to maximum. Quote Link to comment Share on other sites More sharing options...
Juan22 Posted December 13, 2011 Author Report Share Posted December 13, 2011 Thanks sfbp but it also says to adjust it to minimum if necessary, wich gives me the impression that there is no real line out where the levels are set automatically, instead one has to adjust the volume until it sounds right...I want to know if there is indeed an''automatic'' option as in units such as the MZ-R90 or even the MZ-RH1 where one can simply command the unit to switch the output from headphones to 'line-out' Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 13, 2011 Report Share Posted December 13, 2011 You mean you would like a list of units that support the "LINE OUT" setting? The manual is clear - with this explanation about setting to maximum they disclose that there is no MENU way of setting to line out. But that is all that LINE OUT is on these portables..... set volume to maximum. Quote Link to comment Share on other sites More sharing options...
Juan22 Posted December 13, 2011 Author Report Share Posted December 13, 2011 Ok, thanks. Quote Link to comment Share on other sites More sharing options...
