WarRenm0use Posted September 12, 2012 Report Share Posted September 12, 2012 Hi fellas!, I need to know, if someone have the instructions an necessary files to hack the Volume and EQ in the Hi-MD MZ-RH710, recently got one, and i wanna take the maximum power of the MD. Cheers! Quote Link to comment Share on other sites More sharing options...
sfbp Posted September 13, 2012 Report Share Posted September 13, 2012 Have you tried all the usual recipes? No service manual here on the site. I suggest you try the keypresses documented for the RH910. Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted September 13, 2012 Report Share Posted September 13, 2012 Is it a European RH710? If not I don't believe there's any need to attempt the hack. Quote Link to comment Share on other sites More sharing options...
WarRenm0use Posted September 15, 2012 Author Report Share Posted September 15, 2012 I just bought this used RH710, and compared to others Md's, the volume is minimal and doesn't have the custom eq, there is another option better than the hack? Ps: It's an european model. Edit: I got the Service manual, but i don't clearly understand how to get into the test mode, and then, into the test mode, what i need to do? Ps: I have attached an extract of the service manual (The complete ver. it's too big) sony_mz-rh710_ver-1.0_sm Extract_opt.pdf Quote Link to comment Share on other sites More sharing options...
