I have a VPCF115FM since 2010; as some of you may know how good is this machine
I bought an original Windows 8 DVD from www.microsoft.com and made a clean installation, then installed the drivers that i downloaded before using Sony Taxi. everything worked terrific, except for 2 issues :
1) The fan speed is above normal nearly all the time.
there has been a Security file that i downloaded back in 2010 that made the fan noise a little less (On Windows 7) and the same problem appeared again with windows 8, but the security file doesn't work anymore on WIN8
2) The Led and Keyboard Back-light sensor is no more functioning.
After installing my fresh windows 8 i found help in this regard, and it worked for me, but later on i lost the functionality and the VAIO Control center full list disappeared again, and the same trick doesn't work anymore .
Trick used in this link :
1- Download the SFEP driver from a french website
2- Install Shared library
3- Install the Event manager driver
BnSeliim
HELLO VAIOers
Last- install the Control Center.
Can anyone help please
2 answers to this question
