I Just Bought a Sharp MD-MS702 mk
oroville
I think it's this one:
Wow this unit sounds so much better then any sony unit i own what a shock......
Anyone else own one.
Oh yea if anyone has the remote for it or a link to one please pm me thank you.
It is a great sounding unit, even though I owned the MD-MS722 model. These units have ATRAC 24-bit encoding and Digital X-Bass! I think it's much better than Sony's MegaBass or bass output of Hi-MD models.
I have the 701 model (amongst others) and I also find Sharp models generally to be more convenient to use, due to bass boost and stereo/mono select being controlled by buttons on the front rather than buried in menus.
Regarding frequency response last year I did some accurate comparisons. With bass boost turned off all my Sharp MD's gave a more or less flat response, my Sony one's did not. The Sony models all had a small amount of bass boost present even with the function turned off. My Panasonic MR220 also gave a flat response as did my JE480 deck (which you would expect).
Whether or not this applies across the range I don't know as I only have about a dozen or so to compare.
Steve
