KDL-32W650A Wall Mount
Rubiconmike
So i just bought the 32W650A for the man cave.
i want it to mount it in the corner above the computer table.
Well they don`t make one that mounts in the corner.
They do make a Full range mounting arm but it`s for
flat walls.
So i made my own corner Bracket to mount the full range arm to.
Only problem is the TV so far. It does not have the standard mounting hole pattern in the back.
It has two holes upper back and two holes in the bottom underneath the TV.
The arm i'm using has standard flat brackets For a flat surface to mount to.
Any one seen any thing out there or is it back to the shop to fab up something.
6 answers to this question
Weird about the holes. Sounds like they are not VESA (100mm, 200mm or 400mm IIRC).
Sony sometimes chooses a much bigger size than necessary for the weight.
I can relate to your whole "corner" thing, as I tried and failed to get a company to MAKE me a corner mounted stereo cabinet. No &*()_ clue!
What I ended up doing was to put the bracket with folding arm on one of the walls, and then put the TV across the corner by adjusting the angle of the bracket. This worked pretty good. Send me a PM if interested, you could drive over and see it.
Welcome to our forums!
Stephen
Just checking if any one has bought this
Sony TV yet?
I like/need the smaller TV's for my work space.
I have a GoPro black witch is very high res.
so I need 1080 plus to get the full effect.
It is a smart TV but it seams a little bit of a gimmick to me. I use the laptop as my WWW sorce.
So far I'm really liking the TV.
The stock mount is ok but not what I need.
Any one els have one yet.
I bought mine at Best Buy in Canada.
Edited by sfbp
Merged topics
