albero23 Posted July 22, 2006 Report Share Posted July 22, 2006 today when i connected my a1000 with connect it automatically started to delete songs and i only switched the sinc from automatic to manual i din't try to turn it back because i din't want to have no more songs on my playercould anyone help me?thanks in advice Quote Link to comment Share on other sites More sharing options...
albero23 Posted July 23, 2006 Author Report Share Posted July 23, 2006 113 wievs and nobody know a solution? Quote Link to comment Share on other sites More sharing options...
Ascariss Posted July 23, 2006 Report Share Posted July 23, 2006 songs don't get deleted by themselves ever, no computer is that clever to remive them, there has to be some order from the user to remove them. I can think of only a few reasons why this would occur.1. you selected the songs to be deleted from the device on the device.2. songs went missing from the playlists on the pc if you used one.3. songs were removed from the library and they will be deleted from the device as well.did you do anything to the database on the device or in the library? Quote Link to comment Share on other sites More sharing options...
albero23 Posted July 23, 2006 Author Report Share Posted July 23, 2006 it happened when i tryed to run the keywizard of GYM so the original datbase was backupped and then in the new i added GYM's files and after that process all GYM's files(without delete them form the library)were automatically delted so i gave up the keywizard and restored the original database and connect didi this "joke" again (i closed connect before restoring the original database obviously) Quote Link to comment Share on other sites More sharing options...
albero23 Posted July 24, 2006 Author Report Share Posted July 24, 2006 (edited) very thank to all for the big help!anyway i solved the problem Edited July 24, 2006 by albero23 Quote Link to comment Share on other sites More sharing options...
JSP62 Posted July 24, 2006 Report Share Posted July 24, 2006 albero23 said: very thank to all for the big help!anyway i solved the problemPlease be sure to post your solution for the others who has the same problem and what can be done.Thanks Quote Link to comment Share on other sites More sharing options...
albero23 Posted July 25, 2006 Author Report Share Posted July 25, 2006 i created another OMGAUDIO folder and i ran connect and it said deleting songs(in the box in the angle that display infos) and after 1 minute it stopped then closed connect i restored the original OMGAUDIO and i ran connect and it was ok Quote Link to comment Share on other sites More sharing options...
