Sonic Stage not compatible with Windows 8?
ShriDurga
None whatsoever.
The only thing you need is to allow installation of the 64-bit (or 32-bit) NetMD driver by turning off driver signing. Generally this has to be done at boot, and may be done temporarily (for long enough to install your device). If you have lots of different NetMD devices this can be a pain, since each one has to get installed.
I think I will merge this with the thread on W8 if I can find it.
