culp4684 Posted December 10, 2014 Report Share Posted December 10, 2014 I think I know the answer to this but I am going to throw it out there anyway. My SS library is now about ten years old. I purchased a copy of Sufjan Stevens "Seven Swans" long ago just to see how it would sound once transferred. This was probably done in the days before Hi-MD. It is in 132 K Atrac just like all of the material on Connect was at the time. I just tried to transfer it to disc and it failed. There is a message about not having the copying rights for the material. Is there a workaround for this? Thankfully, this was the only album I ever bought from Connect. I think I had some type of song credit at the time as well. Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 10, 2014 Report Share Posted December 10, 2014 Nope. If you can play it, that is your only workaround. Optical out and record afresh (to MD or whatever). Knowing Sony, it's probably an uncopyable signal (SCMS) but if not, then you're in. Quote Link to comment Share on other sites More sharing options...
culp4684 Posted December 11, 2014 Author Report Share Posted December 11, 2014 It won't even play in SS. I seem to remember at the time some notice was given about how to save these. Just how escapes me... Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 11, 2014 Report Share Posted December 11, 2014 If you right click on the SS entry, does it give you options to convert or save? You cannot authenticate against Connect since it's gone. However I wonder if the MP3ConversionTool works on Connect-encrypted tracks? Quote Link to comment Share on other sites More sharing options...
punkrockaddict Posted December 12, 2014 Report Share Posted December 12, 2014 You could playback with FFmpeg and then record it to your Walkman or whatever. I guess this should work at least Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 12, 2014 Report Share Posted December 12, 2014 You could playback with FFmpeg and then record it to your Walkman or whatever. I guess this should work at least Nope. The Connect store used completely different authentication keys from transferred-oma-recordings-to/from-minidisc. So it won't work, and there are so few people out there with samples that it would be impossible to find the keys by tinkering. Quote Link to comment Share on other sites More sharing options...
punkrockaddict Posted December 12, 2014 Report Share Posted December 12, 2014 I thought the used key is a masterkey? Did anybody ever tried FFmpeg to playback ? It would be worth a shot.. Quote Link to comment Share on other sites More sharing options...
dwactor Posted December 27, 2014 Report Share Posted December 27, 2014 I have a folder of .oma files from Sony Connect seven years ago. I recently found that Audacity will play and convert these files. Audacity use FFmpeg to import these files and LAME to export to MP3 files. Both FFmpeg and LAME are plug-ins and need to download from an external web page in order to work. I tried Audacity on one of these files and it successfully export to a MP3 file. Need a program such as MP3tag to correctly label the MP3 file. Quote Link to comment Share on other sites More sharing options...
sfbp Posted December 27, 2014 Report Share Posted December 27, 2014 Maybe I was wrong. Perhaps the ffmpeg method doesn't require the device-specific keys. Note that VLC will play 132kbps ATRAC3 but not ATRAC3+ (the hiMD format). Ffmpeg will play both. Quote Link to comment Share on other sites More sharing options...
Another MD fanatic Posted December 31, 2014 Report Share Posted December 31, 2014 You don't need another programme to tag the MP3 files. When you use Audacity to export MP3's a box comes up for each file where you can input the title, artist, album, etc. If you've only got one album to do it's probably just as easy to do it this way. Quote Link to comment Share on other sites More sharing options...
