Sonic Stage/WINE
bluecrab
Does anyone know if SS will run under Lnx/WINE if using a non-HiMD portable? It looks like I'll be getting a PC laptop, but not one with Windows on it. I would be installing some version of Linux. Thus, the WINE question. Not going to pay for WIndows OS, as even XP (which I have used and like) still costs some $$. Is there a solution for this?
You consider getting a very cheap HP business note book like the nc4400 that come with xp prof. They are very fine dual core 2 ghz from c 2006, and use it just for sonic stage. Will prob last you the rest of your life if u get a good one. If you are in the USA I thiink these note books go for very little these days
The thing is, guys, is that I would get the laptop for free and although I would prefer (in this case) WIN to LNX, the fact is that LNX would also be free and I am comfortable with LNX. But I can't find anything conclusive about WINE's working OK with SS. Well, you never know...maybe an XP or other MS OS disc will turn up! Thanks.
