SilverSurfer Posted July 31, 2015 Report Share Posted July 31, 2015 (edited) I just bought an used car with a built-in Sony MDX-62. I have never used MiniDiscs - the only way I use my autoradio is via FM-Transmitter and Smartphone. So I have no use for this MDX-62 and would like to sell it to somebody who can use it. Thanks for the reply "Inquisitor" - so here are some additional Informations: It's no problem to get any additional parts for this Device if needed. So e.g. the SONY Unilink Cable can be bought here for around USD 10 : http://www.ebay.com/sch/sis.html?_nkw=SONY UNILINK DIN DATA CABLE CD DVD CHANGER iPOD XM SIRIUS TUNER XPLOD US SELLER&_itemId=271156497181As I have mentioned above this Device was in a used car (Audi TT) I just bought. The garage gave me the device after adapting the car to my needs. I have talked with the preowner of the car and he guaranteed to me that this MiniDisc Device is working properly without any problems. I had to remove it from the car because I have never had any MiniDiscs in my life and so for me it is absoutely useless. Whoever is interested in this device and needs to go sure that it works just contact me I will provide evidence (e.g. in form of a short video) if neccesary! Edited August 1, 2015 by SilverSurfer Additional Informations Link to comment Share on other sites More sharing options...
sfbp Posted July 31, 2015 Report Share Posted July 31, 2015 Whoever buys this is going to need the Sony Unilink (BUS) cable, unless you have the model with the RF transmitter. In this case, please post a photo of the RF transmitter. Otherwise as it sits right now, the device is rather unusable (I hesitate to say useless, because it is possible to buy those pieces).And please don't double-post. Thank you. Link to comment Share on other sites More sharing options...
sfbp Posted July 31, 2015 Report Share Posted July 31, 2015 Thanks for the follow up. I'm just astounded that there's no cable with the device, since presumably it was functioning, and needs one to function. Link to comment Share on other sites More sharing options...
