BRAVIA 55W800C wont default to HDMI 1 input ?
BRAVIA KDL-55W800C
1 answer to this question
Your post doesn't make sense.
1. What is HSMI?
2. If you mean HDMI, why do you want to reset FROM HDMI, surely you want it to be set TO HDMI (I've no idea what COX means).
My own Bravia has a habit of being hijacked by certain devices plugged into it whenever they are turned on; so I have the opposite problem to you. There are some settings about HDMI control which have to do with control of the TV by connected HDMI devices such as your cable STB.
Good luck finding the problem. Generally this forum is not the right one for your kind of question, sorry.
