SONY NW-E3 (pulling my hair out)
ARtyrrell
Hello all,
I am having an issue. After packing up my house and moving to Spain, I found in a box (within a box...) my old NW-E3 with USB (yay).
However I did not have the correct disks, after my first bout of hair removal i found this place, which thankfully enabled me to download and install SonicStage (thank you Christopher).
I also attempted to download drivers from sonys own support page, but I cannot get my computer to connect/recognise my NW.
My Device page has a silver monolithic icon called Network Walkman, but it has no associated drivers! try as I might, I cannot find any usable drivers for this device.
Help me please if you can and will.
Regards.
EDIT: windows 7 Bootcamp
2 answers to this question
Sounds like you need a "NetMD driver" for it since that's the only thing I know of that transmits ATRAC3. Can someone tell me the PID and VID? Then I can work on it. I don't think they moved to transmitting via regular block drivers until Hi-MD, which this clearly predates.
If OP (ie you) doesn't know enough to find them out (well, the PID because we know the VID is Sony) someone can find it. Maybe in some install file that I cannot currently lay my hands on. But the 64-bit driver install file needs to be modified, and I can do it for you.
Stay tuned.
