NW-E99
D&BBOY
Anyone on here own a NW-E99?
I've had mine for a couple of years now but it got a bit broken and needs tape to keep it together but still sounds great, just stops when the tape gets loose.
I want a new one as I find it the best 1 gb player ever.
Does anyone know where I can find a new one, can find the E95 but noy the E99
6 answers to this question
I know there are NeW 0 ne's, but look at it. it's great, it took a 40 kph impact with the ground, (tarmac) to make the usb cover to break off, the whole frame is ascue? but it still sounds great, (if kept still).
I just want a new one co's it's the best.
You can drag and drop with ease, perfect for commuting.
I´m getting bored with all this ipod vs. walkman discussions.
peronally, I´m a true Walkman fan. I love walkmans. I think they´re great and there´s no other device that can match them. They are just basic. They have all the things you need to listen to music. That´s the only thing I wanna do with my DAP, listen to music. i don´t have to watch vids or view photos... so I don´t need a big colour screen. But all in all, I´m not an ipod fan, I think the ipod is a good product. It has it good points, but has many weak points to. It´s just ones opinion and taste that desides what DAp is best for him.
If the ipod wasn´t so over hyped, and wooowed every time someone sees it, and if it was not sooo worshipped by half the world and it´s manufacturer, and was a bit cheaper, I think I´d realy like the ipod. It´s a solid product. But for that big pricetag and the big fuss around it, it´s just not good enough. i expect more of a device with that pricetag and all that worshipping to it.
but like I said, it´s jut ones opinion.
I've never considered a ipod, and this is not about one versus the other, I just love the E-99, I would like a new one now mines broken thats all.
Seen a second hand one on amazon, just hoped there were still some floating around, I can but hope.
I have the E99, but I don't think I will offer it for sale. :) It's almost perfect, with the only downsides are capacity and USB1.1. Best bet is to keep looking for it in auction sites, or if there's a Sony outlet in your country, check with them. If you want to upgrade, I definitely recommend the NW-E00x, while their price is still decent (before sandisk/Apple release higher capacity flash players).
I have predicted that the flimsy rubber for the USB cover would probably the 1st one to go.
http://www.audiotstation.com/forum/showthr...p;highlight=E99
http://img76.exs.cx/img76/2387/NWE9909.jpg
