Factory settings, internet no longer works.
NJS.213
Hi,
I've just restored my old Sony Vaio laptop to factory settings (model PCG-91111M). However, when I try to use the internet (chrome) it's a really old version. It will let me search but says 'The web page is not available' for each search result I click on. I think it might be because that version of google chrome is so old but I don't know how to update it without using the internet to update. Any ideas would really help, thanks :)
1 answer to this question
You will have to check the internet actual settings.
This is not about Vaio per se, and you would be better off in a  PC/Win forum.
However, pull a command prompt, type "ipconfig /all" and tell us what you get.
IF  you really think it's Chrome, try IE instead to download something. But first you have have to establish connectivity.
