Perus Posted May 7, 2021 Report Share Posted May 7, 2021 Hi! I recently managed to find a NH1 for a "reasonable" price these days but without the remote and now struggles with setting the clock with my remote from the RH1 (RM-MC38EL) - should that be possible or do I have to find a RM-MC40ELK? Thanks, /Per Quote Link to comment Share on other sites More sharing options...
Richard Posted May 7, 2021 Report Share Posted May 7, 2021 Just connect it via USB to your pc and it will read the time from the computer and store it in memory Quote Link to comment Share on other sites More sharing options...
Perus Posted May 9, 2021 Author Report Share Posted May 9, 2021 Thanks for the suggestion, I didn't know that would work. Unfortunately I don't have the cradle nor the USB cable yet. Guess I need to find myself a USB cable. /Per Quote Link to comment Share on other sites More sharing options...
Richard Posted May 9, 2021 Report Share Posted May 9, 2021 On 5/9/2021 at 7:49 AM, Perus said: Unfortunately I don't have the cradle nor the USB cable yet. Guess I need to find myself a USB cable. /Per Expand I had a feeling you were going to say that.. I don't have my NH1 with me to check if the RM-MC38EL gives you all of those menu options. If you connect it, which options do you have in the "Option" menu? Quote Link to comment Share on other sites More sharing options...
Perus Posted May 11, 2021 Author Report Share Posted May 11, 2021 The menu options from the RM-MC38EL connected gives me all the settings stated in the manual except for the "clock set". I guess it needs three rows to be able to perform that... Quote Link to comment Share on other sites More sharing options...
Richard Posted May 11, 2021 Report Share Posted May 11, 2021 Hmm.. It does sound indeed in that case that the option is only available with the 40ELK. Maybe your best bet is just to locate a USB cable Quote Link to comment Share on other sites More sharing options...
Perus Posted September 1, 2021 Author Report Share Posted September 1, 2021 All this sorted after I found a RM-MC40ELK in a bundle with a NW-HD3 to play with 🙂 /Per Quote Link to comment Share on other sites More sharing options...
Richard Posted September 1, 2021 Report Share Posted September 1, 2021 On 9/1/2021 at 7:15 AM, Perus said: All this sorted after I found a RM-MC40ELK in a bundle with a NW-HD3 to play with 🙂 /Per Expand Excellent - good news. I also tested my NH1 with the 38EL and wasn't able to do anything. Glad you got it working. 🙂 Quote Link to comment Share on other sites More sharing options...
