BearBoy Posted March 9 Report Share Posted March 9 So, I got a new (to me) MZ-R909. Very nice condition and everything seems to function correctly with the exception of a slightly erratic jog dial. It kind of works, some of the time, but often will jump forward/backwards a bit instead of moving one step forward/back and when you push it in to "enter" it suddenly shoots forward or backward in the menus so you enter the wrong one. I can navigate things using the remote or the play/pause/stop/rew/ff button on the recorder (once I've managed to get into the menu using the jog dial) but it's a bit frustrating. Anyone encountered anything similar and managed to fix it? Not sure if the recorder just hasn't been used in years and might "loosen up" with a bit of use. Or if there's any way of getting some contact cleaner into the jog dial somehow. Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 11 Report Share Posted March 11 I’d give it a bit of use before anything more invasive. Sorry can’t be of more use! Quote Link to comment Share on other sites More sharing options...
BearBoy Posted March 11 Author Report Share Posted March 11 Yeah, I really don't fancy my chances of getting it back together again if I tried to dissemble it. Everything's so tiny compared to working on a deck. I got a bit annoyed with it yesterday 🤦♂️ and gave the jog dial a pretty vigorous work out and it seems to have improved a fair bit 🤣 I think I'll just keep playing with it for a while longer and see how things pan out. 1 Quote Link to comment Share on other sites More sharing options...
BearBoy Posted March 18 Author Report Share Posted March 18 This does seem to have pretty much sorted itself out now. I am not 100% convinced the jog dial is quite as precise in its operation as on my other MZ-R909 but it's no longer glitching about erratically. And at least I haven't destroyed the device by taking it apart to try to "fix" it 😆 Quote Link to comment Share on other sites More sharing options...
