Foolish
geezawolf
I downloaded some tunes from the itunes store and think I have been very foolish. Basically, i have a Sony Walkman which uses atrac files and I have Sonic Stage (which is rubbish but can't get the ml-sony thing to work). Anyway, the tunes I downloaded are mp4 files and they won't import in to Sonic Stage. Can anyone help or have I just completely wasted my money?
7 answers to this question
You're kinda' stuck, unfortunately. A less than ideal solution that will, however, still work would be to burn the iTunes tracks to cd and re-rip in ATRAC or MP3. The sound quality will be degraded, but if you want to listen to these tracks on the go, that's pretty much your only (legal) option.
-Nav
Buy a CD-RW, burn the iTunes track to AudioCD, re-rip the CD to MP3/Atrac, erase the CD-RW, repeat as neccessary. Sound quality is degraded, but most people won't hear the difference anyway.
2nd suggestion, get an iPod, and you'll enjoy better integration with iTunes, gapless playback (MP3 and AAC), and unicode.
  geezawolf said:
Why do itunes work with mp4 files anyway? They always used to be mp3 didn't they?
Tracks from iTunes music store has been in protected AAC format since the beginning.
