SonicStage Problem: "Sonicstage converting database"
Descyciede
Hi
recently moved out off my parrents house and bought a new pc.
Downloaded the latest Sonicstage, installed it and yipee again problems!!!!
Everytime i want to start up SS it keeps on converting Sonicstage database.
Checked if my firewall allows SS, no problem, unisntalled and reinstalled it same problem, let it run (for 3 days), same problem...
my gear is the sony vaio pocket...
any suggestions or help???
thx
a desperate Sony user
ok
i've installed SS,
every time i want to start it up, i get a pop up wich says Updating sonic database, sonicstage will be restarted after the updating is complete, when i click ok, it makes a new window wich says converting the sonicstage database with a progress bar, i just leave it running but i've kept it running for 3 days and nothing happens???
Hi, what SS want`s to do is to search for every file in the computer it can recognize as an audiofile (ATRAC, mp3,AAC,WMA and wav(pcm)) and put it to the SS library. It sucks! It finds files from games, videos with separated audiofiles, etc... so in the end the most you have in the library is crap. And presumably your SS find something corrupt or something who turn SS into a loop. Next time press no, and if you want music in your SS library update it manually instead.
I would try the following - download the MDAC repair tool from the downloads here: http://www.atraclife.com/downloads/details.php?file=18
If that doesn't fix the issue - I would try downloading and installing:
1/ MDAC 2.8 SP1 - from here http://www.microsoft.com/downloads/details...;displaylang=en
2/ Jet 4.0 SP8 from here: http://www.microsoft.com/downloads/details...;displaylang=en if you are using Windows XP or from here: http://www.microsoft.com/downloads/details...;displaylang=en if you are on Windows 2000.
