CrazyLexx Posted May 11, 2007 Report Share Posted May 11, 2007 Hi there,I'm currently running the european release of Sonic Stage 4.3 on a German Vista system. Unfortunately I can't get the SS to be installed with a german language setting - I only get english. Any idea how I can manually select which language version is going to be installed?Thanks,Tom Quote Link to comment Share on other sites More sharing options...
Shinji Ikeda Posted May 11, 2007 Report Share Posted May 11, 2007 Hi there,I'm currently running the european release of Sonic Stage 4.3 on a German Vista system. Unfortunately I can't get the SS to be installed with a german language setting - I only get english. Any idea how I can manually select which language version is going to be installed?Thanks,TomQuestions:Were you given a language option when you installed SonicStage 4.3?Was the original language on the Vista system German or English?SonicStage should give you a language option when you first install it. You may attempt to download the German version of SonicStage and see if this installs.http://www.sonydigital-link.com/hotnews/vi...p?l=en&f=nw Quote Link to comment Share on other sites More sharing options...
CrazyLexx Posted June 3, 2007 Author Report Share Posted June 3, 2007 Questions:Were you given a language option when you installed SonicStage 4.3?No, I wasn't prompted to choose a language. The entire setup process is in English.Was the original language on the Vista system German or English?GermanSonicStage should give you a language option when you first install it. You may attempt to download the German version of SonicStage and see if this installs.The way I see it, there is no specific german version of SonicStage - only a multi-language one:"Note: SonicStage CP will be installed on your Operating System language in one of the following languages: English, French, German, Italian and Spanish."Any ideas? Quote Link to comment Share on other sites More sharing options...
CrazyLexx Posted June 10, 2007 Author Report Share Posted June 10, 2007 No further ideas?! Maybe there's some kind of start command which forces a specific language version to be installed...? Quote Link to comment Share on other sites More sharing options...
Richard Posted June 10, 2007 Report Share Posted June 10, 2007 You may want to check out this post for some links for downloading SS4.3 in German (full installer)http://www.minidiscforum.de/forum/viewtopic.php?t=16218 Quote Link to comment Share on other sites More sharing options...
