Inline remote for A608
SimKill
I was wondering if it is possible to use an inline remote with the A608...
I know it isn't much use anyways, but even then I wanted to know.
There may be many people with inline remotes for other players and a A608, anyone willing to give a try???
6 answers to this question
The A608 is a small flash player and does not have the socket for a remote like minidisc and the HD5/A3000 etc. does. It's so small, why would you need one? It would practically be the same size as the player :huh:
I didn't want a remote actually...
I was curious if it'd work or not, coz I was thinkin' that this is an A series player.
I thought that the remote directly connected to the headphone jack.
BTW wats AntiPod telling abt Jog shuttle speed... I see no option like that???
i found it in p36 of A600's operation guide.
go into "menu", then "Cue/Rev" to switch it from "normal" to "rapid".
Note: "only availabe when using the Music Library or Intelliegent Functions in stop mode."
