Zizone_ Posted May 19, 2007 Report Share Posted May 19, 2007 (edited) Hi, I am looking for good Speaker System for my computer. But, my knowledge is somewhat shallow in computer speaker system. Do you guys recommend any particular system? I was looking at this.Thanks in advance. Edited May 19, 2007 by Zizone Quote Link to comment Share on other sites More sharing options...
hk_loves_u Posted May 24, 2007 Report Share Posted May 24, 2007 Hi, maybe you can check out the creative range or a speaker system make from Razer. i think those two brands and product is really good=] Quote Link to comment Share on other sites More sharing options...
Zizone_ Posted May 24, 2007 Author Report Share Posted May 24, 2007 Thanks for the reply. I will check out those as you advised. Quote Link to comment Share on other sites More sharing options...
bangraman Posted June 2, 2007 Report Share Posted June 2, 2007 You could also check out the M-Audio DX4. No lookers to compare with the soundsticks, but performance befits their intention as entry-level studio monitors. http://www.m-audio.com/products/en_us/DX4-main.html Quote Link to comment Share on other sites More sharing options...
navsimpson Posted June 2, 2007 Report Share Posted June 2, 2007 I've heard the Soundsticks, and they're very good - very natural compared to most computer speakers. I imagine the M-Audio monitors would be better though. Quote Link to comment Share on other sites More sharing options...
Zizone_ Posted June 4, 2007 Author Report Share Posted June 4, 2007 Thanks for the info guys. Quote Link to comment Share on other sites More sharing options...
Sparda Posted June 8, 2007 Report Share Posted June 8, 2007 (edited) I also recommend Creative's soundcards, IMO they are the best in the computer industry. I have a Creative SB Live! 24-bit card coupled with Logitech's z5300e speakers. They are entry level spec, but sound very very good. Meaning if you go for the good stuff, imagine what you get. Edited June 8, 2007 by Sparda Quote Link to comment Share on other sites More sharing options...
ceres Posted June 26, 2007 Report Share Posted June 26, 2007 navsimpson said: I've heard the Soundsticks, and they're very good - very natural compared to most computer speakers. I imagine the M-Audio monitors would be better though.although most people tend to dislike monitors in a home cinema setup I think nothing can match them on the desktop. the lowliest 150 Euro/USD retail pair will annihilate everything that logitech and creative can muster. You´ll have to sacrifice some desktop real estate, however.As far as creative goes: I used to like what I got for 70 Dollars with the xfi music in xp but now in vista creative is a farce. I have reverted back to onboard hda bitstream to my av receiver. I hooked up a pair of logitech z10 to the -anal- log out of the xfi and hiss/cracking/popping kills me. Quote Link to comment Share on other sites More sharing options...
