Remote question
Fighting Phantom
1 answer to this question
  Fighting Phantom said:
I'm looking at this remote guide and it makes no mention of the NW-A1200. I'm assuming these remotes will work with it as well, correct?
http://www.atraclife.com/forums/index.php?showtopic=1490
Also has anyone tested the RM-MC35ELK to see if the folder navigation will work?
Yes, the RM-MC35ELK will work fully with the NW-A1200, as it will with the A3000/A1000. The folder navigation also works. I'm not too sure about the other remotes though, I don't think they control all the functions of the A3000/A1000/A1200. The RM-MC35ELK is recommended for the A3000/A1000/A1200.
Edited by ANGRYBADGER
