sifun Posted July 15, 2007 Report Share Posted July 15, 2007 If i display an album say like a soundtrack in my search query in sonicstage with multiple artists, the album comes up with 1 track in them for each artist on the album, even though the album is the same name..Is there a fix to display it so that the album is listed properly? Quote Link to comment Share on other sites More sharing options...
Richard Posted July 15, 2007 Report Share Posted July 15, 2007 (edited) Set the "'Compilation Album"' property for the album to be checked and if you then check the options under the properties of each track to be "Tracks In The Compilation Album" this should move them to the same album. Edited July 15, 2007 by richyhu Quote Link to comment Share on other sites More sharing options...
sifun Posted July 16, 2007 Author Report Share Posted July 16, 2007 thanks for the reply! what a ball breaker this sonicstage software is! I mean if the album name is exactly the same, i'd think they would automatically assume its a compilation.Bah. Wheres the suggestion box at sony. Quote Link to comment Share on other sites More sharing options...
Shinji Ikeda Posted July 16, 2007 Report Share Posted July 16, 2007 thanks for the reply! what a ball breaker this sonicstage software is! I mean if the album name is exactly the same, i'd think they would automatically assume its a compilation.Bah. Wheres the suggestion box at sony.It all depends on what assumption you want the software to make. It is possible to have two albums of the same name from two or more different artists. Whereas this are totally different albums and not compilation. I strongly believe this is why SonicStage includes the compilation check box. Quote Link to comment Share on other sites More sharing options...
