NWZ-A81* technical specs/service manual
slyyls
25 answers to this question
I want to learn , how can i get in the service menü.
In the nwz-a80* its like that:
1. Turn the power on.
2. Press the [bACK] key for 1.5 seconds or more, the home menu
is displayed.
3. Slide the [HOLD] key to set the hold on.
4. While pressing the [OPTION] key, press the key as following
order.
up - right - down - left - up - play - up - left - down - right - up - play
5. The set reboots when the [HOLD] key is slided to set the hold
off, and the color bar is displayed in the lcd.
6. Enter the test mode when the [bACK] key is pressed in the
state of step 5.
But i could not find for nwz-a81*.
is displayed.
order.
state of step 5.
Thats nice :)
But what is it good for?
I believe the service menu that you indicated is for the NWA-800 series..
I'll check the service menu for the nwz series.. i'll post it maybe by nxt week.. B)
Edited by kodigo
kodigo,
I have an NWZ-A816 and tried to enter service mode as described on the screen you provided but it didn't work. the unit doesn't reboot. There is a warning about the voltage. Does that mean it won't work unless the player is fully charged or is it just a recommendation ?
Or maybe I'm doing it wrong...
the way I understand it :
- switch on device
- go to home menu
- set hold switch on
- press "option" key and do the following combination while pression "option" key : up - right - down - left - up - play - up - left - down - right - play
- a color bar is supposed to appear on the screen
- set hold switch off
- unit is supposed to reboot
- press "back" key to enter service mode
is that right ?
kodigo,
- switch on device
- go to home menu
is that right ?
The service manual says switch off the device, then hold the back button for 1.5 or more until it returns to the home menu.
hello,i need that menu too.
someone asked up there,why we need it,it is cause of in some areas sony sells this players with limited sound output. but i guess this will fix if we enter that service menu.so it would be nice to get it :excl:
I do not think the issue relates to volume limiting on some Sony players. That is no longer an issue. Only the original author knows why they want the manual.
