villekille Posted January 31, 2008 Report Share Posted January 31, 2008 I can get the a806 for a good price but now I can see that there isn't support for Wav-audio. Is there any way to get uncompressed data to a806 player? I need to listen to white noise a lot and it really is noticeable if you compress it in any way.. Quote Link to comment Share on other sites More sharing options...
0 juli_ Posted January 31, 2008 Report Share Posted January 31, 2008 villekille said: I can get the a806 for a good price but now I can see that there isn't support for Wav-audio. Is there any way to get uncompressed data to a806 player? I need to listen to white noise a lot and it really is noticeable if you compress it in any way..I think someone said it does play linear PCM which I think is the same as lossless in that it's not compressed.Maybe someone else can confirm? Quote Link to comment Share on other sites More sharing options...
0 markey Posted January 31, 2008 Report Share Posted January 31, 2008 juli said: I think someone said it does play linear PCM which I think is the same as lossless in that it's not compressed.Maybe someone else can confirm?Not too sure if the A80x plays linear PCM but I know the S70x range does. Quote Link to comment Share on other sites More sharing options...
0 Zizone_ Posted January 31, 2008 Report Share Posted January 31, 2008 (edited) Hello,NW-A800 series does support linear PCM (WAV) playback.EDIT:Sorry I confused with A810 series. I think it only support ATRAC Advanced Lossless.Following formats are supported:NW-A800 series:MP3/ATRAC/WMA/AAC/ATRAC Advanced Lossless.NWZ-A810 series:MP3/WMA (both DRM and non-DRM playback; also supports VBR, variable bit rate)/AAC (non-DRM only)/linear PCM (WAV). Edited January 31, 2008 by Zizone Quote Link to comment Share on other sites More sharing options...
0 shaft69 Posted February 1, 2008 Report Share Posted February 1, 2008 (edited) use the Atrac Advanced Lossless Edited February 1, 2008 by shaft69 Quote Link to comment Share on other sites More sharing options...
villekille
4 answers to this question
