Remove Connect Player From SS 4.3
imagine_
Do you guys know if it possible to remove the connect store from sonicstage? I know that the old versions of the canadian sonicstage 4.x had no connect player, and it was lighter than the US version. Now that the connect store is closing down, and that sony will stop supporting sonicstage, is they probably won't be releasing a new version without it.
So is there a way to remove it ourselves?
Thanks in advance.
