Signal compressed type Speech compression type MP3/WMA/ATRAC/linear PCM/AAC *4 *5 *6
Video compressed type -
Still picture compressed type -
Display 3 line indicatory color liquid crystal
Bluetooth function -
FM tuner - *7
Direct encoding -
Drip-proof correspondence -
video/still picture indicatory direction -
Still picture sliding show -
Bundled application software SonicStage CP
Substance operation correspondence OS Windows Vista ® Home Basic or Home Premium or Business or Ultimate/Windows ® XP Home Edition or Professional or Media Center Edition after 2004 & 2005 SP2
* We do not correspond to OS of 64 bit edition
Search method List indication search - 8 kind *8
Initial search -
50 sound sequential line changing -
Jacket search -
Play mode Repeat -
Shuffle -
Intelligent shuffle - 4 kind *9
Counter function -
Sport mode -
Sound quality Noise cancelling function -
13.5mmEX headphone -
DSEE -
Clear stereo -
Clear base -
Equalizer - 5 bands
VPT acoustic engine -
Dynamic no Malayan the -
Channel list -
Channel setting -
Subtitle -
Sound -
Video recording -
Electronic program schedule (EPG) -
Something related to power source Charge pond Built-in type lithium ion
USB charge charge time (approximately/time) 1 *10
AC adapter charge charge time (approximately/time) Selling separately AC adapter AC-NWUM50 correspondence approximately 1 hour charge
Charge pond duration (approximately/time) At the time of music playback: 30 (ATRAC), 28 (MP3) *11
Bit rate separate record time *1 MP3/ATRAC *2 48kbps Approximately 180 hour 00 minutes
64kbps Approximately 133 hour 20 minutes
128kbps Approximately 66 hour 40 minutes
256kbps Approximately 34 hour 20 minutes
320kbps Approximately 27 hour 20 minutes
broadcast (terrestrial digital broadcast) 350kbps -
Video 384kbps *3 -
768kbps *3 -
*1 In case of the long haul continual playback which exceeds charge pond duration, the middle, charge is necessary *2 With "SonicStage CP" it cannot record with 48/64kbps MP3 *3 Bit rate of image. As for bit rate of sound 128kbps *4 With substance reproducible MP3 file format format: MPEG-1 Audio Layer 3, bit rate: 32 - 320kbps (VBR), sampling frequency: 32/44.1/48kHz *5 Copyright it cannot play back the WMA file which is protected. With substance reproducible WMA file format format: WMA and bit rate: 32 - 192kbps (VBR), sampling frequency: 44.1kHz *6 Copyright it cannot play back the AAC file which is protected. With substance reproducible AAC file format format: AAC-LC and bit rate: 16 - Also numerical value outside standard and outside guarantee includes 320kbps (VBR) (depending upon sampling frequency), sampling frequency: 8 (only NW-A910/A820/S710F/S610F series) /11.025/12/16/22.05/24/32/44.1/48kHz *7 Reception frequency FM: 76.0 - 90.0MHz TV: 1 - 3ch *8 All tune/the artist/the album/genre/release year/100 tunes which are heard well/the play list/8 types of album which was transferred recently *9 4 types of shuffle/artist link shuffle/time machine shuffle/sport shuffle which are heard well *10 3 minute charge -> 3 hour playback correspondences (as for details please read each commodity page) *11 At the time of built-in charge pond use and ATRAC 132kbps playback when (approximately 30 hours), at the time of MP3 128kbps playback (approximately 28 hours), electric power consumption setting "Save ON Super", setting the clear stereo, the equalizer and dynamic no Malayan the to "off", standard
Guest buggy
SPECS AS FOLLOWS
Specifications Capacity 4GB
Basic information Built-in memory medium Memory
Playback Music
FM tuner - *7
Direct encoding -
Initial search -
Jacket search -
Play mode Repeat -
Shuffle -
Counter function -
Sport mode -
DSEE -
Clear stereo -
Clear base -
Equalizer - 5 bands
Channel list -
Channel setting -
Subtitle -
Sound -
Video recording -
Input/output terminal Headphone output -
Headphone utility installed capacity (JEITA 16 Ω /mW) 5 + 5
Form of connected with the personal computer/substance terminal Hi-Speed USB/direct USB
Size mass Maximum external size [ JEITA ] (width × height × depth /mm) 83.7×22.3×16.2
External size [ JEITA ] (width × height × depth /mm) 81.9×22.1×13.8
The charge pond it includes, [ JEITA ] (g) 28
Video 384kbps *3 -
768kbps *3 -
- : MEANS NOT AVAILABLE
Edited by buggyLink to comment
4 answers to this question
