Spacer for analog recording
Guest Anonymous
Guest Anonymous
When I am analog recording, sometimes the spaces between tracks are not recognised. Can anyone point me to somewhere I could download a 3 second spacer to put in my RealPlayer playlist to get around this please?
Many thanks.
Robbo
heyy there,
u can overcome this problem by using a small simple program called mp3 2 cd that is available here : http://home.online.no/~hpersett/mp32minidi...disc/mp32md.exe
it automatically adds a space in between ur songs so the md can pick it up and add another track...it works quite well and it supports some soundcards with optic out also...i don't kno if u can put ur RealPlayer playlist in the program but u can go and check it out...
hope this helps... 8)
btw if that link is broken can sum1 plz msg me so i can search up a new url 4 ppl 2 d/l the program from...
  • 3 weeks later...
If you could use winamp, theres a plugin 'gen_pause' which automates the process http://home.bip.net/urbansan/gen_paus/
there is a better one for WinAMP called WinCUE... it is a full program designed for MD...
if u have a Hardwire connection to ur MD it can even Title and Eject it for you...
