900 model inserts like a floppy drive?!?
The_Stamp
Do you think that having the "floppy insertion" would be good or bad?
  1. 1. Do you think that having the "floppy insertion" would be good or bad?
    • Good! (I've always played with my VCR when i was young!)
      7
    • Bad! (Is that suggestive or what?)
      4
    • Meh.
      2
check it out:
user posted image
if you look on the side of it, you'll see a dark strip, approximately the thickness of a MD. hmmm. perhaps you insert the disk like a floppy on this model. Could this be good or bad?
Possible Pros:
the entire inside (with motors and such) would never be exposed, always covered by a flap
Possible Cons:
Flap could break, external stuff (like coins in your pocket blink.gif could get in, short-circuiting it WCS)
if there is a flap, they had BETTER have done something with the coins in pocket issue! i was seriously going to buy this, and this comes up! i might have to recede to the 800 unsure.gif
well if this model is indeed a slot in model then it would be like very interesting indeed...i've owned a Sharp 722 model that had was slot in...but if the flap on this unit is similar to the one employed yonks ago on the 722 then i wouldn't worry about it too much...it was very sturdy and it doesn't let any coins in...but then again their eject mechanism was a little unique...
Guest Anonymous
People, people! You're not paying attention!
Look at the direction arrow embedded on the unit in the upper-left corner. It will load MD's just the same as the rest, from the top side, with the unit open. That strip on the side is just a decoration.
Think about it. Why would they make a slot drive? It would make the unit bulkier, heavier and consume a lot of battery power. A slot drive only makes sense on decks.
  Quote
*Looks at his R37*
It is strange, but some construction techniques survive for a long time in Sony-products.
I agree with Jay and Kurisu, that this is a clamshell type and with the plastic visible at the side, it seems to be mechanically constructed like my R37. And that means, that the drive and PCB is mounted into a plastic frame and the top and the bottom shell are mounted onto that, leaving the side exposed.
However, I strongly suggest not to project too much into a picture and to wait for the real units to arrive.
Heck, it's only a month to go... :smile:
Grrr... And we here in Europe have to wait until June/July. mad.gif
  • 2 months later...
yup it's the plastic thingy like in the construction of the MZ-R70 not no space to insert the disc..but think of this...i've had some MDS that i accidentally sat on n they're bent now when i slide them in n i just eject the stuff outa the unit the disc don't even pop out just above the unit so i can hold it u know i gotta stick my pinky in there n pull it out so altho having it work like the floppy mechanism's not a bad idea..i'd be in trouble..always having to hold a screew driver on me :smile: .... but it'd save on moving parts but what about the eject mechanism..what u think that'd b like..digital i'd hope not like that of the floppy drive or one of those old Sharp MDs i've seen that uses a leaver..they'll probably hook up something to their already slide eject buttons or something u think???? huh.gif
  Quote
Why would it consume a lot of battery power?!?
There was a quite recent panasonic player if i'm not mistaking that had a slot-in. I wonder if it had a better eject mechanism than those old sharp 722 that would break like nothing.
