Ruiner Posted May 19, 2004 Report Share Posted May 19, 2004 Ok so here's my problem i bought a MZ-NE410 from my friend an he did not have the sofware nor the usb cable so i just downloaded the software and installed a driver and i am using a usb cable from my mp3 player it connected perfectly but when i try to load mp3 to the MD it cancels and brigns up an error message and it some times loads the first song and cancels when i put in a second one .... what maight be my problem??? :wink: If more info is needed just ask me and i'll post it. all help will be apreciated! :smile: Quote Link to comment Share on other sites More sharing options...
Malow Posted May 21, 2004 Report Share Posted May 21, 2004 u should uninstall all md software, and install SonicStage 2 , to see if works. it is more stable. it contains the md driver. u will find it in first NetMD/MDLP forum page. (sticky) Quote Link to comment Share on other sites More sharing options...
Ruiner Posted May 21, 2004 Author Report Share Posted May 21, 2004 yes i have tried that already i'm thinking it might be the usb cable maybe Quote Link to comment Share on other sites More sharing options...
jeff peterson Posted May 21, 2004 Report Share Posted May 21, 2004 I get a similar message when the battery is low, this unit doesn't pull power from the USB cable, AFAIK. Quote Link to comment Share on other sites More sharing options...
Malow Posted May 21, 2004 Report Share Posted May 21, 2004 if in sonicstage the net md shows up, and make list of songs, i belive your usb cable is ok. Quote Link to comment Share on other sites More sharing options...
Ruiner Posted May 22, 2004 Author Report Share Posted May 22, 2004 ill change the batery see what happens then i will update! but thx for the help so far! Quote Link to comment Share on other sites More sharing options...
Ruiner Posted May 23, 2004 Author Report Share Posted May 23, 2004 yes!! it worked thank you!!!!! Quote Link to comment Share on other sites More sharing options...
The_Stamp Posted May 23, 2004 Report Share Posted May 23, 2004 make sure that the unit is plugged in. it REALLY kills the battery when your transfering stuff. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted May 28, 2004 Report Share Posted May 28, 2004 make sure that the unit is plugged in. it REALLY kills the battery when your transfering stuff.that will be a thing of the past when the new Hi-MD units come out... :happy: Quote Link to comment Share on other sites More sharing options...
crazeybt1 Posted May 29, 2004 Report Share Posted May 29, 2004 :grin: i can hardly wait u have no idea Quote Link to comment Share on other sites More sharing options...
