Sony Insider Forums
TopDog
Looking for an AC Adapter for MZ-1
Hi, first post on this forum.
I'm looking for an AC adapter for Sony MZ-1. Needs to be 10.5 volt output at 1amp. I'm having a hard time finding a universal adapter that fits the bill. Does anyone know where I can original OEM adapter or a universal that will work? Thanks in advance.
Share this post
Whatever you do *don't* try using a 12 volt adaptor because you'll damage the unit.
Share this post
If you haven't already, try checking out universal adapters that state that they are "for digital cameras." I've seen them with high V and mA (1000-2000 usually). For starters, things like the Energizer ER-AC1 might work, but it doesn't state the mA/A. Good luck!
Share this post
The part number for MZ-1's AC Adaptor is # 157385612 (*please read post #16 for correct part number) and you can order it from Sony DAPC (if you are located in the States) for $11.95. Otherwise, contact your local Sony Service Center/Parts and Accessories with the part number as reference.
Share this post
:blink: Wow, I'm surprised anything super-old is that cheap coming from the DAPC. The replacement earpads (just the covering, not even including the memory foam underneath) of my Sony headphones are priced at almost US$50! Each!
Share this post
Thanks Ishiyoshi, you are da Man! Part ordered. I was really beginning to think I was going to have play Russian roulette with AC adapters. Thanks Again! :good: :
Share this post
While this was true in 1992 and perhaps even 1999, today's switching adapters are much more precise in their output voltages and have better tolerances for variation.
The MZ-1/2P adapter is a brick to be sure. A large transformer-based adapter with the 10.5V 1000mA output as stated.
Most transformer-based adapters have very wide fluctuations in their outputs. Meaning an adapter that is rated for 9V will probably float over 12V with no load on it. As a load is applied the voltage goes down and it will begin to stabilise in output as the current draw gets closer to the rated current output for the adapter.
A switching adapter, on the other hand, will usually actually put out close to the voltage it's rated for, load or not. So using the float and load voltages for the MZ-1 adapter and applying them carefully with settings from a switching adapter may result in a better outcome than the fried MZ-1 documented on the EB so long ago.
If you get a switching adapter with multiple settings (universal) and err on the side of caution with the voltage settings, I'm sure you could get a compatible voltage for the MZ-1 to work with.
There is some danger in this (as we've seen the case documented on the EB) as the MZ-1/2P don't have any internal power protection as do new units (today's units will flash "Hi DC-in" or give a similar message if slightly overvoltaged). Overvoltage a 1 or 2P and you'll likely fry it. So I would use caution but I don't think you're guaranteed to burn it out as you would have done in the past, trying different transformer adapter voltages.
If I had a switching universal I'd try it myself on my 2P, but unfortunately I don't have one and the only switching adapters I do have are not enough voltage...
Share this post
On the same subject anyone know whee I can obtain a MZN510 power adpater in the uK?
The MZ-N510 employs an AC Adaptor with a rated output of 3V, 500mA and rated input of 120V, 60Hz, 3W. Instead of acquiring its original bundled AC adaptor, you could get a Sony World Voltage Type AC Power Adaptor: AC-EC30A, rated output of 3V, 1000mA and rated input of 100-240V, 50/60Hz, 6W . It will work very well with your N510 and you should be able to get one easily from your local Sony store.
Share this post
Your knowledge astounds me.
The adapter you are talking about is it OK for UK 240V?
Share this post
Yes, the AC-EC30A will work in UK 240V environment. It's a world voltage AC Adaptor; in fact, you can even acquire other 3V AC Adaptor of similar specifications. As for the AC-EC30A, the only additional item you may need to acquire is a UK adaptor plug, type G. For your reference, the AC-EC30A features a type A flat blade plug; hence the need for a UK type G adaptor plug.
Share this post
The part number for MZ-1's AC Adaptor is # 157385612 and you can order it from Sony DAPC (if you are located in the States) for $11.95. Otherwise, contact your local Sony Service Center/Parts and Accessories with the part number as reference.
I received the part today. Sad to say it is the wrong part. I did not receive an AC adaptor (transformer) what I did get was an Adaptor, Change. Its a plug with two round prongs on it for use in countries outside of the US. Oh well guess my hunt for a AC adaptor goes on.
Share this post
I apologize for the wrong part number and will contact Sony DAPC for the correct part number; then perhaps you can return the plug and reorder the AC Adaptor from Sony DAPC. Once again, my apologies for any inconvenience caused. :sorry:
Share this post
@TopDog: I called Sony Japan and managed to acquire the correct part number for MZ-1's AC Adaptor - sorted by region:
US: 1-466-884-11
Japan: 1-466-887-11
UK: 1-466-886-11
Australia: 1-467-364-11
Unfortunately, Sony DAPC no longer stocks the original MZ-1 AC Adaptor but they have a replacement part – 1-475-555-41 with a price tag of $76.95. For your reference, the replacement adaptor AC-PBD1’s specifications:
•Rated Input:120V, 60Hz, 0.30A
•Rated Output: 10V, 1.3A
•Dimensions (Approx.): 2 x 2 3/4 x 1 1/4 in (w/h/d)
•Color: Black
I was assured by Sony Japan that the replacement AC Adaptor will work with the MZ-1, but please confirm with Sony DAPC before proceeding with the order. Once again, my apologies for any inconvenience caused.
Share this post
$77 US? That's ludicrous! However, I was thinking the original adapter could not be as cheap as mentioned above...
Again, I would do what I said and try using a universal switching adapter instead, as it will probably work out okay...
Share this post
I just checked and ebay has a complete MZ-1 unit, one owner, original box and all cables, adaptor, etc., for sale. Current bid is at 99 cents. It might be worth bidding for it and you'll get the original adaptor. Seller is in the USA.
http://cgi.ebay.com/Sony-Md-Walkman-MZ-1-M...VQQcmdZViewItem
Regards,
Ed
Share this post
US: 1-466-884-11
Japan: 1-466-887-11
UK: 1-466-886-11
•Color: Black
Where can I purchase the replacement AC adaptor ??????
Share this post
Regards,
Ed
Hi Ed,
APPARENTLY This listing (110078568879) has been removed or is no longer available.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
